Connectivity Problem with Wreckfest - Server/Client Mismatch
Application Wreckfest
when i install wreckfest i get the error message “server/client mismatch” every time i try to connect to the server. also the port 27015 and 27016 is shown as “not listening”
  • activate “run in docker”
  • installing the template
  • add “AMP” user to docker as mentioned in the infobox
  • change some setting like servername, player, use steam scripts etc.
  • shutdown container and clicked update
