Connectivity Problem with Wreckfest - Client Version or data does not match server's
Application Wreckfest
created a new wreckfest instance with default settings.
connection to server shows: Client Version or data does not match server’s.
  • instance updated and game installed
  • changed server name and game mode
  • trying to connect to the server shows error: Client Version or data does not match server’s.
This has been answered in Discord
the answer in discord is missleading and wrong.
problem still exists.
my first Wreckfest instance is running fine, this first instance is also using different ports than the default ports. so change port to “default” is not the solution because it is not the problem
I said in Discord to “try” using the default ports, because Wreckfest handles ports badly and doesn’t obey command line flags and configs. I didn’t guarantee it would solve your problem
If you want to be a dick about someone trying to help, good luck with your life
you wrote here “has been answered in discord” and you solution in DC Ticket is: change the other game ports. as described that doesn’t work because its the same game.
thanks for your help so far.
maybe someone else has some information
