Connectivity Problem with Windrose – Crash on Client Connect (Wine / gRPC Assertion)
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
Application Windrose
I am running a Windrose server through AMP on Linux using Wine.
The server starts correctly and appears reachable externally.
However, clients cannot successfully connect:
  • Using Invite CodeServer not found
  • Using Direct IP → returns to menu (no error shown)
Key Findings
  • Port forwarding is correctly configured (UDP 7777 open externally)
  • Server is listening on:
    0.0.0.0:7777 (UDP)
  • Firewall (UFW) is disabled
  • Direct connection settings configured correctly:
    "UseDirectConnection": true,
    "DirectConnectionServerAddress": "<public-ip>",
    "DirectConnectionServerPort": 7777,
    "P2pProxyAddress": "0.0.0.0"
Critical Behavior (Important)
When a client attempts to connect:
  1. Connection is initially successful:
    Client connection verified successfully
  2. Server begins sending initial data:
    Send initial data. TotalSize 2475953 B
  3. Server crashes immediately with:
    ASSERTION FAILED: result.bytes_transferred == buffer_->Length()
    ... grpc ... windows_endpoint.cc:355
  4. Followed by full crash stack trace from:
    WindroseServer-Win64-Shipping.exe
Conclusion
This does not appear to be a networking issue.
The server:
  • Accepts connections
  • Begins data transfer
  • Then crashes during replication
This strongly suggests:
A compatibility issue between Windrose (Windows build), Wine, and gRPC networking layerReproduction Steps
  • Install AMP on Linux (Ubuntu 24.04)
  • Create Windrose instance (GenericModule / Wine)
  • Start server
  • Connect via:
    • Invite Code → fails
    • Direct IP → triggers crash
  • Observe server crash in logs
Additional Notes
  • Issue started after recent Windrose update
  • Server previously worked for a few days
  • No containerization or unusual network setup involved
  • Same behavior regardless of client retry
Request
Can you confirm:
  1. Is Windrose server officially supported under Wine/Linux via AMP?
  2. Is this a known issue with recent updates (gRPC / networking layer)?
  3. Any recommended Wine version or configuration?
Been coming across this same error for the last few days and can’t get my server back up and running. I was able to get it running on my local machine with the same world. But my set up in the cloud is a bit more complex. I am running it on a ARM64 server on Oracles free tier. I am using FEX-Emu and Wine. No luck finding anything to help with it yet.
This 100% is a networking issue due to non-blocking send calls. Load the save into a Windows game and it works just fine. Upgrade wine to at least 9.18 to fix it.
Here’s the bug report and resolution, which is upgrade wine, for the nerdy.
https://bugs.winehq.org/show_bug.cgi?id=10648
And how to update to the latest by skipping your distro’s version, at least a guide I used. Note, make /sure/ you get rid of all pieces parts of wine from your distro before upgrading.
https://gitlab.winehq.org/wine/wine/-/wikis/Debian-Ubuntu
I’d suggest testing Wine 10.x, possibly compiled from source. Wine 9.x gave me issues compiling.
Warning untested code below.
1. Install build tools/deps
sudo apt update
sudo apt install -y \
  build-essential git flex bison gcc g++ make pkg-config \
  libx11-dev libxext-dev libxrender-dev libxrandr-dev libxi-dev \
  libxcursor-dev libxinerama-dev libxcomposite-dev libxdamage-dev \
  libxfixes-dev libfreetype6-dev libfontconfig1-dev \
  libasound2-dev libpulse-dev libdbus-1-dev libudev-dev \
  libvulkan-dev libgl1-mesa-dev libglu1-mesa-dev \
  libgnutls28-dev libunwind-dev
2. Get Wine 10 source
cd /root
git clone https://gitlab.winehq.org/wine/wine.git
cd wine
git fetch --tags
git checkout wine-10.0
Wine 10.0 was released by WineHQ in January 2025.
3. Build 64-bit only
mkdir build64
cd build64
../configure --enable-win64 --prefix=/opt/wine-10
make -j$(nproc)
sudo make install
Not sure if I did this?
4. Add command links
# sudo ln -sf /opt/wine-10/bin/wine64 /usr/local/bin/wine64
5. Test
wine64 --version
# wine --version
Expected:
wine-10.0
