Connectivity Problem with Voyagers of Nera - Cannont Connect to server
Application Voyagers of Nera
Have the instance running but can not connect to the server and i’m pretty sure the ports are forward properly
  • Forward the Ports
  • Allowed Firewall access
  • Confirmed in config files everything was correct
Same Problem. Its only one UDP Port. Local working.
Edit:
I have much more Gameservers with AMP Running and all working from Outside.
Only Voyagers of Nera not working.
Maybe there is a Template Error?
[/Script/BoatGame.BGCustomGameSettings]
ServerPort=27700
QueryPort=27800
Dont see this in File, but if i put it manually in, not work, too :frowning:
I was running into the same issue with the local connection to my Voyagers of Nera server working but the outside tunnel wasn’t working.
Turns out the issue was that I needed to add the server port and query port to the host server config file located here: BoatGame/Saved/PersistedData/CustomConfig/CustomHostServerUserSettings.ini
For me it looked liked this after adding the two ports:
[/Script/BoatGame.BGCustomHostServerSettings]
HostServerDisplayName=
HostServerPassword=
MaxPlayers=10
AutosaveTimerSeconds=300
ServerPort=7778
QueryPort=7779
That wouldn’t have been the issue at all
If you are hosting the server behind playit or similar, then you need to set the Public IP Selection Mode accordingly
