Connectivity Problem with Vintage Story - Unable to Connect Externally
Application Vintage Story
Where I was able to connect via my external IP to the server, I can no longer do so. I can still connect on a local server IP, but that doesn’t do any good when trying to get friends into the server. Has worked flawlessly up to this point. No changes have been made, as far as I’m aware. Haven’t played in a while, due to real life being busy but went to connect today and have had no luck, other than a direct connect.
  • Start Server on port 42420
  • Set Port Forwarding to 42420 TCP/UDP
  • Attempt connection via external IP
