Connectivity Problem with VEIN - Issues starting a VEIN server instance
Application VEIN
Setup Vein server
  • Configured server settings after creating the instance
  • tried to connect to the server
  • serger is not showing in the list when i search
Have you forwarded ports?
Not that currently the server list only shows 200 servers at a time. The VEIN devs’ recommendation is to type in part of the name and click search multiple times until it shows
i just deleted and im re-doing port forwarding… will let you know. momentairly
Havent been able to get my server up at all and it’s failed to create every time, so lemme know how it goes. Guessing i just need to do some port forwarding too.
Your issue sounds different, better to create your own post
I’ll do some troubleshooting on my end for a day or two before doing so. Nothing better to do, and should help me learn.
Running it on Windows or Linux? If Linux, using Docker?
*As a docker on an Ubuntu Server VM on TrueNAS Community Edition.
Could be the CPU mode if you are not using “Host pass-through”. But, yeah, create your own ticket, or jump on Discord
lol that fixed it. I had CPU configuration as Custom since that was working in the past, but yep my Nightingale and Vein servers came up immediately. And also the VM booted alot faster than normal too. Thanks dude! Any way i can tip/upvote you or anything? I’m new here.
still cant connect to the server…i double and tripple checked the ports and still nothing, can we chat on discord?
I assume they are the ports allocated in amp
No need to forward the sftp port unless you intend using that instance’s sftp outside your network
Create a thread on discord if you like
