Connectivity Problem with Valheim - Valheim server does not show online
Operating System Linux - Ubuntu 22.04.4 on x86_64
Application Valheim
AMP shows it running but when i look at the Valheim connection window it does not show it online
  • checked port forward on router
  • updated the server
  • restarted the server
What connection window are you referring to here? Are you using the option to join via IP in-game?
i turn on Valheim, have have the server added in the join game list. but it says the server is not online. I have verified ports are in router. I did have this all working on this same server. i had a cpu failure so i replaced the cpu and reinstalled linux and then add amp. since then my satisfactory server works great but i can not get Valheim to work. Also when i look at amp panel i see the game port does not go green but the steam query port does
update it seems when i put on crossplay this is when the game port will not connect. however even with out cross play i can not connect to vaheim server i setup using valheim join game
