| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Decadeus’ v2.4.6.6 (Mainline) |
| Virtualization | None |
| Application | Valheim |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
I am trying to allow friends playing on Xbox to join my Valheim game server, but I can’t seem to find a way to generate a Join Code for them. I’ve used Steam to run Valheim and connect to the server instance both from another laptop and from the same machine as it’s running on, and thought I would see the Join Code on the pause menu, but cannot find it. Is there a way, in AMP, to generate a Join Code and/or is there something I’m doing wrong? Thank you!
- Setup Valheim game server
- Enable crossplay
- Setup port forwarding on my router
- Tested PC connections from local network - Success
- Tested PC connections from remote network - Success
- Tested Xbox connections from remote network - Failure
