Connectivity Problem with tModLoader - External connection issue
Application tModLoader
The steam connect link returns an invalid app id when attempting to join. Attempting to join through direct IP times out. Joining through IP on a local device is successful. Port forwarded the port labeled Server with TCP/UDP. Host device is set up with DHCP reservation. Attempting to start an instance with no mods installed and default world settings returns a similar result.
  • Set up tmodloader instance with startup behavior set to nothing
  • Update instance and install desired mods
  • Set desired world settings
  • Port forward and start server
  • Have an external client attempt to connect
Having same issue, did you find a fix?
