| Virtualization | Docker |
| Application | TeamSpeak 3 |
| Module | GenericModule |
| Current State | Failed |
when attempting to connect to a teamspeak server with a newly created instance over the default ports I am unable to join and connections fail with “failed connection inintialization”.
- create new instance for teamspeak server
- Change voice to teamspeak defaults (9987)
- change remaining ports to those available in teamspeak module github (AMPTemplates/teamspeak3server.ini at main · CubeCoders/AMPTemplates · GitHub)
- start teamspeak server
- attempt to connect using default port using teamspeak client
