Field | Value |
Product | AMP ‘Callisto’ v2.5.0.12 (Mainline) |
Virtualization | Docker |
Application | Team Fortress 2 (64 Bit) |
Module | GenericModule |
Running in Container | Yes |
Current State | Ready |
The only way that I am able to try and connect is via the Steam://connect function. This gives me the following error message (sadly in german): “serverbindung nicht möglich da vom server angegebene anw-id ungültig ist”. I would translate it as follows: “Server connection not possible, since the application-id given by the server is not valid”. Sounds to me like the server is not aware that it is a TF2 server. I do not know where I have to add it. Thanks for you help!
- Create Server
- add Game Server Login Token
- add Server Account ID
- Server Account Token
- I DID NOT yet port forward, but am testing in my local LAN
- try connecting via web interface
- try connecting via ip
