| Product | AMP ‘Phobos’ v2.6.5.2 (Mainline) |
| Virtualization | Docker |
| Application | StarRupture |
| Module | GenericModule |
| Current State | Ready |
A StarRupture instance was created and configured (password set and “Start New Game” enabled). The connection was tested using both the internal IP address with port and the public IP address. The server was then shut down, “Load Saved Game” was selected, and “Start New Game” was disabled. Despite these steps, it is still not possible to connect to the server.
- StarRupture Instance created
- StarRupture instance config set, password and “Start New Game” option selected
- Try connecting to the internal IP with port as well as via public IP
- Shut down the server, select the “Load Saved Game” option, and deactivate “Start New Game.”
