Connectivity Problem with Sons Of The Forest - Ports do not open up
Application Sons Of The Forest
DSL [Self-Tests] [Networking] Testing server ports against public ip 70.190.3.90…
01:16:09
#DSE [Self-Tests] [Networking] UDP GamePort [8767] is closed. Please fix and restart.
01:16:11
#DSE [Self-Tests] [Networking] UDP QueryPort [27016] is closed. Please fix and restart.
01:16:13
#DSE [Self-Tests] [Networking] UDP BlobSyncPort [9700] is closed. Please fix and restart.
#DSE [Self-Tests] [Networking] Some ports are closed or already in use and the game server will not be accessible. You may need to setup port forwarding and open them in your firewall, or change port numbers if they are used by some other software. Alternatively, consider using the LanOnly configuration if you didn’t intend to make your server public. Please fix and restart.
#DSE [Self-Tests] Please restart the server.
  • restarted amp
  • restarted guest operating system
  • updated system
