Connectivity Problem with Sons Of The Forest - Port showing closed
Application Sons Of The Forest
I am hosting a Sons of the Forest dedicated server on Linux. The server fails its self-test, stating that UDP ports 8766, 27016, and 9700 are closed. Despite multiple troubleshooting steps, the game server does not bind to the assigned ports, making it inaccessible externally.
  • Checked firewall (UFW) status – It’s inactive, so firewall is not blocking ports.
  • Verified that no process is listening on port 8766 (ss -tulnp | grep 8766 returned nothing).v
  • Tried different ports (e.g., 8888) – Still not working.
  • Checked Sons of the Forest server logs – Showed Steam API errors & ports closed.
  • Verified AMP instance logs – Confirmed that networking self-test fails (ports closed).
  • Reinstalled/Validated game files with SteamCMD – Success but no change.
  • dited the Sons of the Forest server config manually – Ports set correctly in server.cfg.
  • Restarted the AMP instance multiple times – No effect.
  • Checked for port conflicts (lsof -i :8766) – Nothing is using the ports.
Im having the same issue i cannot even start the game on my local lan, error game does not exist.
did you manage to find a solution?
