| Product | AMP ‘Phobos’ v2.6.4.2 (Mainline) |
| Virtualization | Docker |
| Application | Sons Of The Forest |
| Module | GenericModule |
| Current State | Ready |
After opening Sons on Windows 11 PC, clicked on Multiplayer, Join, Direct and entered the Endpoint info.
- Verified the instance is running. It is.
- Verified the ports are available through the firewall
- Tested connectivity from Windows 11 on local network. Ping works as well as test-netconnection with port 2224.
- Used PortQueryUI to test UDP ports and the test was inconclusive.
- Ran updates and rebooted server.
