| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Callisto’ v2.5.1.0 (Mainline) |
| Virtualization | None |
| Application | Seven Days To Die |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
Hi,
Me and some friends wanted to setup an 7D2D server with Darkness Falls mod. Setting up the server is no problem and no errors. But no one else outside my network can join. I have tested all the ports and everyone is open, both in the firewall and router. We even tested with minecraft and that works with no issues. So is there something am missing?
- Install 7D2D with Darkness Falls
- Config server to the correct settings
- Port forward needed ports on ruter and firewall
- Run server
- Server running fine no error
- Trying to connect but gets the error
