| Operating System | Windows - Windows 11 Pro on x86_64 |
| Virtualization | None |
| Application | Satisfactory |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
so this was working on a prior update 8 version of the server, but recently, it wont load on my global ip. no setting were changed, except an update. I can connect on my local network using my machines IP and the correct port, but even though i confirmed my router settings are correct, i still get an error saying it timed out trying to connect over the global ip or anything off my network. self hosted outside of amp seems to work, but that defeats the purpose of using amp to manage my server
- restarted server and hardware
- recreated server from scratch with stock port
- updated from working version to current and it broke
- went to reddit and was told to edit the multihome setting in the startup file, but that did nothing
