Field | Value |
Operating System | Windows - Windows Server 2019 on x86_64 |
Product | AMP ‘Callisto’ v2.5.0.4 (Mainline) |
Virtualization | None |
Application | Rust Dedicated Server |
Module | RustModule |
Running in Container | No |
Current State | Ready |
I can’t connect to Rust RCON using Passthrough. The UI doesnt let me change the port from 7777. When I look in the instance ports, the passthrough port isnt there, and adding a custom port doesnt change rcon passthrough from using 7777. I am unable to connect to RCON using Service login or otherwise regardless. I do see that the service is listening on port 7777, but it always ends in “bad password” during connection attempts
- Enable Console Passthru for Rust Instance
- Try to connect to that port using Service Login through admin account and a user account with appropriate permissions
- Try to change the port from 7777
