| Operating System | Windows - Windows 11 Pro on x86_64 |
| Product | AMP ‘Proteus’ v2.8.0.4 (Mainline) |
| Virtualization | None |
| Application | Project Zomboid |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
I’m struggling to figure out why I cannot connect a PC to my Project Zomboid server. I must be missing some connectivity step or firewall issue. Game server is running on Windows 11 Pro so I also checked Windows Firewall and I see some rules it automatically generated. There are four rules that show ports TCP 6, UDP 16263, UDP 16264, and TCP 17017. I thought the ports should be 16261 and 16262, can anyone comment?
- Checked AMP instance that ports are green and listening
- Confirmed that server has started in console and steam is enabled
- Used cmd ping command on gaming PC to confirm local server IP connection
- Router software ports forwarded UDP 16261 and 16262 to game server
