| Product | AMP ‘Callisto’ v2.5.1.8 (Mainline) |
| Virtualization | None |
| Application | Project Zomboid |
| Module | GenericModule |
| Running in Container | No |
| Current State | Ready |
So this is my settup: i run the AMP server at home, i dont have a public IP at home so i tunnel it via VPN to a server that has a public IP, this server is running the vpn server and a nginx proxy manager, in that i set up the stream to route the ports to the vpn ip of the AMP server. Normally this should work fine but it doesent. I know there is no problem with the VPN so its either nginx or AMP that has some sort of safety mechanism built in taht i dont know. Maybe you can help me out and tell me more about how to access the server from the outside.
- I can connect via VPn directly and it works fine
- when i try to connect via my server running nginx proxy manager with the stream set up it doesent work
- my firewalls etc should be configured fine, its just that i dont get a response from the AMP server
