First, confirm whether the hardware has the configuration required by Palworld.
If you use Intel’s 13th or 14th generation chip CPU flagship, this may also be the cause of the failure.
A VPS running Debian 12 with Docker was mentioned, so I’m obligated to say that this isn’t Hostinger support, this is the forum for AMP. Hostinger does not set their support URL correctly.
