| Product | AMP ‘Phobos’ v2.6.5.2 (Mainline) |
| Virtualization | Docker |
| Application | Palworld |
| Module | GenericModule |
| Current State | Ready |
I have a linux dabian server running docker, AMP and a playit.gg tunnel. I can’t seem to set it up so that it uses the proper public port. I have tried to set the game port to the same port as the playit.gg tunnel. I have tried to edit the server’s ini, however it keeps reverting back to the same PublicPort=8211 value. I have tried changing the PublicPort via the command line argument box, and the config box offered in the gui, but it hasn’t work. I also discovered when you use the box in the gui that edits the Palworldserversettings.ini, it just adds the value to the end, but doesn’t overwrite the existing value. Please help.
- Created server
- created a playit tunnel
- had friend try to join
