Connectivity Problem with Palworld - application reaching its memory limit and dropping
Application Palworld
application reaching its memory limit and crashing, this morning alone it happened 3 times, when it crashes it is necessary to manually start the instance
  • start in the application
  • the application reaches 7 gb of memory and drops the instance
  • It is necessary to manually start the instance
Palworld requires 16GB to function properly. So this is to be expected with a 7GB limit.
