Connectivity Problem with Minecraft - Unable to connect to Minecraft server
In minecraft game app on mobile I am not able to connect to the server at the running IP location. The application sate says “unable to run” I am not clear on what to do. I have checked all of the settings and troubleshooting in discourse. I notice when checking ports using ‘ampinstmgr table’ that the 19132 port shows closed. but the other ports show listening.
  • Start server
  • Restart server instance
  • Checked settings in Amp via SSH
You may want to see if this guide (then update after following those steps) helps, otherwise you can download the Bedrock server binary from microsoft and upload it over SFTP.
