| Operating System | Windows - Windows 11 Home on x86_64 |
| Product | AMP ‘Callisto’ v2.5.0.4 (Mainline) |
| Virtualization | None |
| Application | Minecraft |
| Module | MinecraftModule |
| Running in Container | No |
| Current State | Stopped |
ported a modded server in to AMP, it works perfectly outside of AMP. when ran trough AMP it’s impossible to connect with the IP or “localhost” but i can connect from clients on the same network trough the LAN section. the ports are forwarded properly as it works outside of AMP.
- Imported Server
- imported server settings
- started the server
