| Product | AMP ‘Phobos’ v2.6.3.2 (Mainline) |
| Virtualization | Docker |
| Application | Minecraft |
| Module | MinecraftModule |
| Current State | Ready |
The server is kicking players and restarting upon doing so, with the player seeing an internal exception of “java.net.socketexception: connection reset.” i’ve turned off the sleep mode as far as I can, allocated enough memory, and 8 cpu cores are allocated. This isn’t a large server, and is just vanilla 1.21.10. TPS and all others are fairly stable, but 20 seconds in the game freezes on the client end.
- join the server
- do stuff at spawn for 20 seconds
- issue happens
The following report directory log is consistent with this issue:
-— Minecraft Network Protocol Error Report ----
// It’s the tubes, they’re clogged!
Time: 2025-10-25 13:13:24
Description: Packet handling error
java.net.SocketException: Connection reset
at java.base/sun.nio.ch.SocketChannelImpl.throwConnectionReset(Unknown Source) ~[?:?] {}
at java.base/sun.nio.ch.SocketChannelImpl.read(Unknown Source) ~[?:?] {}
at io.netty.buffer.PooledByteBuf.setBytes(PooledByteBuf.java:255) ~[netty-buffer-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.buffer.AbstractByteBuf.writeBytes(AbstractByteBuf.java:1132) ~[netty-buffer-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.socket.nio.NioSocketChannel.doReadBytes(NioSocketChannel.java:356) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:151) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:796) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:732) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:658) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:562) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.util.concurrent.SingleThreadEventExecutor$4.run(SingleThreadEventExecutor.java:998) ~[netty-common-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.util.internal.ThreadExecutorMap$2.run(ThreadExecutorMap.java:74) ~[netty-common-4.1.118.Final.jar:4.1.118.Final] {}
at java.base/java.lang.Thread.run(Unknown Source) [?:?] {}
A detailed walkthrough of the error, its code path and all known details is as follows:
– Head –
Thread: Netty Client IO #13
Stacktrace:
at TRANSFORMER/minecraft@1.21.10/net.minecraft.network.PacketListener.fillCrashReport(PacketListener.java:33) ~[client-1.21.10-20251007.142004-srg.jar:?] {}
– Connection –
Details:
Protocol: play
Flow: CLIENTBOUND
Is Local: false
Server type: OTHER
Server brand: vanilla
Stacktrace:
at TRANSFORMER/minecraft@1.21.10/net.minecraft.network.protocol.PacketUtils.fillCrashReport(PacketUtils.java:47) ~[client-1.21.10-20251007.142004-srg.jar:?] {}
at TRANSFORMER/minecraft@1.21.10/net.minecraft.client.multiplayer.ClientCommonPacketListenerImpl.storeDisconnectionReport(ClientCommonPacketListenerImpl.java:141) ~[client-1.21.10-20251007.142004-srg.jar:?] {}
at TRANSFORMER/minecraft@1.21.10/net.minecraft.client.multiplayer.ClientCommonPacketListenerImpl.createDisconnectionInfo(ClientCommonPacketListenerImpl.java:134) ~[client-1.21.10-20251007.142004-srg.jar:?] {}
at TRANSFORMER/minecraft@1.21.10/net.minecraft.network.Connection.exceptionCaught(Connection.java:155) ~[client-1.21.10-20251007.142004-srg.jar:?] {}
at io.netty.channel.AbstractChannelHandlerContext.invokeExceptionCaught(AbstractChannelHandlerContext.java:346) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.AbstractChannelHandlerContext.invokeExceptionCaught(AbstractChannelHandlerContext.java:325) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.AbstractChannelHandlerContext.fireExceptionCaught(AbstractChannelHandlerContext.java:317) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.DefaultChannelPipeline$HeadContext.exceptionCaught(DefaultChannelPipeline.java:1324) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.DefaultChannelPipeline.fireExceptionCaught(DefaultChannelPipeline.java:856) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.handleReadException(AbstractNioByteChannel.java:125) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
at io.netty.channel.nio.AbstractNioByteChannel$NioByteUnsafe.read(AbstractNioByteChannel.java:177) ~[netty-transport-4.1.118.Final.jar:4.1.118.Final] {}
– System Details –
Details:
Minecraft Version: 1.21.10
Minecraft Version ID: 1.21.10
Operating System: Windows 11 (amd64) version 10.0
Java Version: 21.0.8, Azul Systems, Inc.
Java VM Version: OpenJDK 64-Bit Server VM (mixed mode, sharing), Azul Systems, Inc.
Memory: 163330720 bytes (155 MiB) / 933232640 bytes (890 MiB) up to 4294967296 bytes (4096 MiB)
CPUs: 16
Processor Vendor: AuthenticAMD
Processor Name: AMD Ryzen 7 7800X3D 8-Core Processor
Identifier: AuthenticAMD Family 25 Model 97 Stepping 2
Microarchitecture: Zen 3
Frequency (GHz): 4.20
Number of physical packages: 1
Number of physical CPUs: 8
Number of logical CPUs: 16
Graphics card #0 name: NVIDIA GeForce RTX 4080 SUPER
Graphics card #0 vendor: NVIDIA
Graphics card #0 VRAM (MiB): 16376.00
Graphics card #0 deviceId: VideoController1
Graphics card #0 versionInfo: 32.0.15.8108
Graphics card #1 name: AMD Radeon™ Graphics
Graphics card #1 vendor: Advanced Micro Devices, Inc.
Graphics card #1 VRAM (MiB): 512.00
Graphics card #1 deviceId: VideoController2
Graphics card #1 versionInfo: 32.0.12033.1030
Memory slot #0 capacity (MiB): 16384.00
Memory slot #0 clockSpeed (GHz): 4.80
Memory slot #0 type: DDR5
Memory slot #1 capacity (MiB): 16384.00
Memory slot #1 clockSpeed (GHz): 4.80
Memory slot #1 type: DDR5
Virtual memory max (MiB): 39799.91
Virtual memory used (MiB): 20122.43
Swap memory total (MiB): 7936.00
Swap memory used (MiB): 0.00
Space in storage for jna.tmpdir (MiB): available: 350082.44, total: 1906937.00
Space in storage for org.lwjgl.system.SharedLibraryExtractPath (MiB): available: 350082.44, total: 1906937.00
Space in storage for io.netty.native.workdir (MiB): available: 350082.44, total: 1906937.00
Space in storage for java.io.tmpdir (MiB): available: 350082.44, total: 1906937.00
Space in storage for workdir (MiB): available: 350082.44, total: 1906937.00
JVM Flags: 2 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx4096M
Debug Flags: 0 total;
Class Processors:
00.00%: neoforge:computing_frames (marker)
00.00%: neoforge:runtime_enum_extender
04.96%: neoforge:access_transformer
00.05%: neoforge:mixin
00.00%: neoforge:simple_processors_default (marker)
00.01%: neoforge.coremods:field_to_getter.net.minecraft.world.level.biome.biome
00.01%: neoforge.coremods:field_to_getter.net.minecraft.world.level.block.flowerpotblock
00.01%: neoforge.coremods:field_to_getter.net.minecraft.world.level.levelgen.structure.structure
00.17%: neoforge.coremods:method_redirector
Mod List:
client-1.21.10-20251007.142004-srg.jar |Minecraft |minecraft |1.21.10 |Manifest: 5cca83162f4c397b62e4abe032da69128727825dafec5a98a91da34b7c1a4498
neoforge-21.10.33-beta-universal.jar |NeoForge |neoforge |21.10.33-beta |Manifest: 32e44c28e4911308453915e7f815b1c13c82e905ce7bdaf66f8e122ed00cba57
spark-1.10.152-neoforge.jar |spark |spark |1.10.152 |Manifest: e6d42cc4c3ae923c02be8ee6cae0d8bcd3fd7144243123792dd9103a9c555e66
Crash Report UUID: 37ba6ccc-2e09-40f7-8cac-dc3ceee7dd8c
FML: 10.0.25
NeoForge: 21.10.33-beta
