Connectivity Problem with Minecraft - Server not showing or responding to ping
Hello,
I am running a modded Minecraft server using Forge/NeoForge.
The server starts successfully and the console shows “Done”, which indicates it is running properly.
However, when I try to connect from the Minecraft client, the server does not show any ping and does not load. It appears offline in the multiplayer list.
I am using the correct Minecraft version and matching Forge/NeoForge version on my client. I am also connecting using the provided IP address and port.
Could you please check if the port is properly open and if there are any firewall or network restrictions preventing connections?
Thank you.
  • Installed Forge/NeoForge server through panel
  • Started the server successfully (console shows Done)
  • Added server IP and port in Minecraft client
  • Server does not show ping and cannot connect
