Connectivity Problem with Minecraft - Server is lagging a lot
The server is very unstable and lagging a lot,fall damage takes about 10 seconds to register.
  • I created the instance
  • Entered the server
  • And then server doesn’t work
You’ll want to make sure that the server-side render distance is reasonable (the default is 10), then use the Spark plugin/mod to diagnose the CPU performance issues further
