Connectivity Problem with Minecraft - Problems Connecting to a Forge Server
I created a new server. Did some tests on base Minecraft (Java Edition 1.21.4) and it is reachable. I followed the steps to install forge for 1.20.1 which is the version I have for my mod pack but it doesn’t allow me to connect, as if the server didn’t exist. I tried running it with only one mod, with all mods and with just forge but nothing worked, I need help ASAP.
    1. Tested with base Minecraft
    1. Followed the official steps to install forge on the server
    1. Started up the server with forge install, it does not work
This is not Hostinger support, just the forum for AMP, but we can give you pointers on what to check.
Make sure that the server has fully started, then try connecting anyway.
If that doesn’t work, try using the IP of the VPS instead of the domain Hostinger gave you.
