Field | Value |
Product | AMP ‘Phobos’ v2.6.0.6 (Mainline) |
Virtualization | Docker |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | Yes |
Current State | Stopped |
I can join the server, however, when other people try to join with the same mods, they cannot join. I tried restarting and using a port that did work but nothing. We changed the forge version and after restarting the server people were still unable to join. Is it a specific mod everything is in Forge format and everything is the correct version. I tried changing the seed and no one could join so I switched back to default settings only changing the RAM allocated and difficulty. I do not know what I can do I’m just tryna play.
- I restarted the server and changed the port to a server that already worked
- Connected to a server without mods that did work and tried again with mods but did not work
- Multiple people tried joining with different versions of forge installed and server restarted
