keelan
3 November 2023 23:14
1
Field
Value
Operating System
Windows - Windows 10 Pro on x86_64
Product
AMP ‘Decadeus’ v2.4.6.6 (Mainline)
Virtualization
None
Application
Minecraft
Module
MinecraftModule
Running in Container
No
Current State
Sleeping
For some reasons not able to connect locally to the server - have updated to latest paper version, have tried both ip settings IPV4 loopback and the 0.0.0.0 one, not sure what else to try
Created MinecraftInstance
Updated to latest Paper version
Tried both IPV4 Looback and the 0.0.0.0 one
The server should work on 0.0.0.0 (means all network interfaces).
Double check that the server has started and that the port is open in your firewall.
keelan
3 November 2023 23:46
3
Still no luck
Have allowed port 25565 thru host pc and separate game pcs firewall, inbound and outbound (pretty sure both is correct)
still not able to connect locally
Weird, and just a general sanity check, the server is on port 25565 and the server’s console is showing some output?
keelan
3 November 2023 23:53
5
Yes indeed - console shows output and says it has been started under port 25565
I’m not entirely sure on how to diagnose further on windows, might be worth a computer reboot tbh.
Mike
4 November 2023 18:29
7
You’re not putting 0.0.0.0 into Minecraft are you?
system
Closed
4 December 2023 18:30
8
