Connectivity Problem with Minecraft - Missing mods when trying to join
Product AMP ‘Callisto’ v2.5.0.12 (Mainline)
When attempting to join the server, it says that the server is missing some mods, even though I am joining through the same modpack as the one I uploaded to the server.
  • I downloaded the zip file off of cursed forge
  • I uploaded the zip file into the mods folder
  • Then I ran the server and when I attempted to join it gives me the error
Did you select the right server type for the mod loader the pack uses?
Yes, I had forge selected
Do the logs say that the mods are loading?
Also make sure that you didn’t just upload the manifest zip, cause that does nothing.
Most modpacks have a server zip that you would upload into the main server folder and unzip.
