Connectivity Problem with Minecraft - Minecraft server
when friend is trying to join it says connection timed out
  • give Frend log in for server
  • tries to join says connection timed out
  • tries to join again and cant
Check the logs for errors, check that you’ve port forwarded correctly, and that you’ve given your friend the right public IP
there are no errors in the log how do i do the port forwarding
You’d port forward the game port in your router (google your router’s model plus “how to port forward”)
i port forward the ip but it is still saying can’t connect
Test with a tool like this one:
https://mcsrvstat.us/
