Connectivity Problem with Minecraft - "Minecraft server-side problem with missing mods"
Operating System window - Debian GNU/window 11
Hello, when I try to connect to the server, it tells me “The Lightman’s Currency mod channel failed to connect and the Mekanism mod channel failed to connect” I tried to fix the problem but I can’t find the solution
  • server configuration, mods installation, launch via forge, and then the problem was there
  • I did my research on google chat gpt and deepseek but I did not find the solution
  • I reinstalled the mods several times and for me everything is correct
Did you set the Server Type to Forge and put the mod .jar files in the server’s mods folder?
yes but i put it on neoforge
i have all time this screen
The mods aren’t on the server. Make sure you have the mods in the server’s mods folder, and that the server Jar is Autoselect
