Michal
6 February 2025 09:47
1
Field
Value
Operating System
Product
AMP ‘Phobos’ v2.6.0.10 (Mainline)
Virtualization
Docker
Application
Minecraft
Module
MinecraftModule
Running in Container
Yes
Current State
Ready
not listening to game port
started server on bungie proxy
what should i do more? it should work
still doesnt work after restarts and all
Did you already follow Diagnosing Connectivity Issues ? Also check with ss -tulpen | grep 12345, replacing 12345 with your port, through SSH to see if the port is listening. Could be AMP displays it wrong. And check the logs. Maybe there is an error.
It’s suggested to use Velocity, as it’s more secure and more performant than BungeeCord. (more info on that here https://discourse.cubecoders.com/t/minecraft-proxies-and-you/17673 )
One thing to check would be to see if the bungeecord config has the right port in it
system
Closed
8 March 2025 17:52
4
