Connectivity Problem with Minecraft - Maxed out CPU
Virtualization QEMU_KVM
Hi,
Is there a way to increase the CPU max usage on the Minecraft usage because it is using it at max and we are getting server crashes because of it
  • Start server
  • Join server
  • Server crashes
Minecraft servers are mostly single threaded, so all you can really do is manage your server’s usage.
Here’s a guide that has a few tips on reducing usage:
If you have the disk space, pregenerating terrain using the Chunky plugin/mod can also be helpful
You can also check to see if increasing the max tick time/watchdog helps
