Connectivity Problem with Minecraft - It says authentication servers are unavailable
Product AMP ‘Phobos’ v2.6.0.10 (Mainline)
Disconnecting Panda_Will (/76.115.56.225:55944): Authentication servers are down. Please try again later, sorry!
User Authenticator #2/ERROR08:02:59
Couldn’t verify username because servers are unavailable
Server thread/INFO08:02:59
Panda_Will (/76.115.56.225:55944) lost connection: Authentication servers are down. Please try again later, sorry!
  • Start Server
  • Open Client
  • Try to connect
Sometimes that is caused by an actual auth server outage, other times it can be caused by a DNS issue on the machine you installed AMP on.
You could check to see if you’re still having the issue, and if you are, go through and double check your DNS settings on the system.
