Connectivity Problem with Minecraft - I cant open any port
Current State Installing
Hello, I have two problems. I can’t open minecraft port, even setting in router and windows firewall, also kapersky. And my AMP shows that java is not installed, even when it is and I restart. Can you help me?
  • Start instance, open port in firewall and router
  • Tried to connect
  • Connection refused in local and external
What version of minecraft are you trying to run, and what version of java do you have on your pc? Are the ports not opening in your router when you set them, or do you not know how to forward them?
