Connectivity Problem with Minecraft - getsockopt on minecraft with forge installed
Product AMP ‘Deimos’ v2.7.2.0 (Mainline)
We tried with Minecraft without mods(vanilla) to entering the server, and it worked, so the problem is in the connection with modded clients on the server.
Steps:
  1. Create a instance for Minecraft Java
  2. Configure to work with Forge and update
  3. On Client side, try to access the server with the same version of forge
  4. The client will not connect
We tried with different versions of the game and versions of forge, every time with same results.
  • Create a instance for Minecraft Java
  • Configure to work with Forge and update
  • Add 1 mod just to test if it’s working
  • On Client side, try to access the server with the same version of forge
  • The client will not connect
