Connectivity Problem with Minecraft - Error when attempting to connect to server
Everytime I try to connect to my SF4 server I get disconnected because of the following error : Internal Exception: com.google.common.util.concurrent.UncheckedExecution Exсерtion: java.lang.IllegalStateException: Recipe minecraft:wooden_door (net.minecraft.item.crafting Shaped Recipes@72641613) produces unregistered item minecraft:wooden_door (net.minecraft.itemitemDoor@59929ac)
  • Create a new instance of minecraft with forge and java 8 jdk
  • Copy the skyfactory modpack, mods, config, resources, scripts, and a world save to the file manager
  • Start the server and join with curseforge modpack downloaded
  • Disconnected because of an internal exception error
Double check that both the server and client are on the same version, then I’d suggest starting a world locally, save+exit, then upload that world to the server, as the server doesn’t generate the modded terrain by default
Thank you for the reply but I’ve already done all that and it still didn’t work. I’ve also solved the issue.
Turns out the mistake was on my part and I uploaded the modpack itself to the server files instead of the server pack.
So if anyone has the same issue, make sure that you are downloading the server pack from curseforge, not the modpack, and upload that to the server files.
