Connectivity Problem with Minecraft - error joining the server
when we try to join “internal exception: java.net.socketexception: connection reset” appears
  • create the server
  • put the mods in the folder
  • run the server
  • try to join the server
Make sure that you’ve selected the right modloader (Server Type) and version for the mods that you’re using
