Connectivity Problem with Minecraft - CPU and TPS too low
I left the Holy Hoster service for exactly the same reasons, and it just that the CPU and TPS are maxed even before getting into the server just by loading everything. So, server side it gets frozen, but I can still move my character, even when it’s only me who’s playing in the server right now due to testing. So is there any plan with a better cpu performance or something?
  • Play in the server just after connectio
  • I made a change/action, and I can still move around
  • The change is simply not being made
  • I get kicked out of the server and it reboots
This is the forum for AMP, and not Hostinger support, so we can’t really help you in terms of picking one of their plans.
If you already have 2-3 CPU cores dedicated to your VPS, going to a different plan won’t help unless you’re running multiple MC servers, since the major operations in MC mainly rely on single-threaded performance.
I’d also suggest reading the server’s logs and crash-reports to see if you can resolve whatever’s causing the crash.
