Connectivity Problem with Minecraft - connection timed out
Virtualization QEMU_KVM
connection times out upon joining
  • started server
  • tried to connect
  • connection times out
Usually some sort of network issue, or with modded servers the mod-sync process takes too long.
If it’s a modded server, just try reconnecting a few times to see if it kicks over.
server has plugins but isn’t modded. My network should be fine.
I would suggest double checking your firewall and port forwarding
Do I need to set up Port forwarding on the hostinger vps or is it already enabled?
No clue, we are not Hostinger. I would recommend contacting them if you continue to have networking issues.
