Connectivity Problem with Minecraft - Connection Timed out: no further info
Everything goes well, but when trying to connect, especifically when there is no ‘world’ folder on the file manager, we get the message of “server overloading”, I thought it was the tick settings config, so I changed it to -1, but even like that, we still can’t connect into the server.the status tab shows everything’s okay, so Im out of ideas rigth now, please help.
  • added the correct version of forge into the server
  • loaded the mods that we wanted
  • ran the server
The server overloading message can be ignored as long as the TPS stays at/around 20. That has nothing to do with networking.
“Connection timed out: No further information” just means the player took too long to connect.
On both the client and the server, you can add the following Java arg to lengthen the initial join period.
-Dfml.readTimeout=180
In AMP you just add it under Java and Memory, and for the client side, you will need to google “{insert client name} how to add startup Java arguments” and put it there.
