Connectivity Problem with Minecraft - Connection Refused in MC server
After trying and trying to get a MC server setup, after each time i try to connect to the given IP amp gives for connection, in minecraft the connection is refused. I try on the default gateway, and ipv4 address of my server pc but that also does not work. I port forwarded 25565, 8082, and 2225 though i know that 2225 isnt needed. No matter what i’ve done the connection is always refused
  • create minecraft instance
  • go through settings, apply how much ram to use
  • port forward given ports
  • update amp inst manager on firewall
  • try to connect to server
Port 8082 is not needed.
Did you already follow Diagnosing Connectivity Issues
