Connectivity Problem with Minecraft - Connection issues
Virtualization QEMU_KVM
I started the server but is really lagged when the players try to play. I dont know which is the reason for the lag, when the resources should be sufficient
  • Create server
  • Set config
  • Join server
Minecraft is primarily single threaded and the Vanilla game is just slow in general.
If you’re playing vanilla I would suggest using the Paper server type.
If you’re using a large modpack, then this is quite normal and I’d suggest you read this
Hi, is not the first time using this modpack on hosts. The lag is like comming from server side, breaking blocks or running.
Just to note, we’re not Hostinger support, so if you’re having issues with their hardware, go to their support.
If you’re hosting this on your own hardware, then I’d suggest looking into the Spark mod to see if you can narrow down the sources of lag/TPS drops.
