Connectivity Problem with Minecraft - Connection Failure
We tried to install ATM10 modpack, using filemanager, creating mod directory, put all the .jar files. Server start but we can’t connect us. Thanks for helping us
Failed to connect to the server : Connection timed out: getsockopt
  • Go to Direct Connection
  • Enter ip with port
  • Try to connect
If you’re with Hostinger, try using the IP Hostinger gave you instead of the domain name
