Connectivity Problem with Minecraft - Connect only by phone hotspot
Well yeah some of my friend can connect but one and myself cannot connect to the minecraft server of SFTP though fillezilla, i can connect if i am on my phone wifi hotspot tho, same for my friend
  • I have checked nat, and i have the same on my phone and home wifi
  • I have checked my router firewall if it was blocking some specific port
  • I can connect to the server though telnet but i cannot ping it form my cmd
Try using the IP of the VPS that Hostinger gave you, rather than the domain.
InFKNcredible, aha i’ve been trying to debug this for hours could’t make it work, but i still can’t connect to it though fillezilla tho also with regualr IP
With FileZilla you need to make sure you select SFTP and not FTP and the right port, it doesn’t always do it automatically. (same login details as your AMP user)
