Field | Value |
Operating System | Linux - Debian GNU/Linux 11 on x86_64 |
Product | AMP ‘Decadeus’ v2.4.5.0 (Mainline) |
Virtualization | QEMU_KVM |
Application | Minecraft |
Module | MinecraftModule |
Running in Container | No |
Current State | Ready |
$ sudo -u amp ampinstmgr ports
[Info] AMP Instance Manager v2.4.5 built 19/06/2023 22:49
Please enter value for Instance Name
>[x]
[Info] Port usage for [x] ([x])
[Info] Instance is currently running.
[Info] LISTENING 8082 TCP (Core.Webserver.Port)
[Info] LISTENING 19132 UDP (CustomPort.a7e7fc35-2535-479b-8cde-f106f14a40b5)
[Info] LISTENING 8066 TCP (CustomPort.0a032b74-ff12-48f8-9715-c4ff9d5a8584)
[Info] LISTENING 1025 Both (CustomPort.070e96b9-c0de-4da4-baa2-0fd002a12a3b)
not present in ufw, so manually needed to create applicable firewall rule for external access (but is listening and does work)
- checked application running
- FileManagerPlugin.SFTP.SFTPPortNumber, MinecraftModule.Minecraft.PortNumber in web ui, but not
ampinstmgr ports
- fixed connectivity issue by manually adding firewall rule, but the ports still not shown in ampinstmgr
