Connectivity Problem with Minecraft - Can't connect to neoforge server (but will connect to vanilla)
So I’ve been struggling with this for hours and I can’t get it to work. I’m trying to get NeoForge to run on it, specifically version 21.1.219. (I have the same client installed)
When I run the server on vanilla, it works. But when I change it to NeoForge it doen’t seem to connect to the server, even though the server is online. I get the error code:
getsockopt
Just to be clear, when I run it on vanilla I can connect with no issues.
When I switch it to NeoForge, it runs the server but does not let me connect.
    1. Open minecraft neoforge 21.1.219 client
    1. Add a new multiplayer server on minecraft with the ip: srv1332476.hstgr.cloud:25565
    1. It should say: getsockopt. even though the server is online on hostinger
EDIT:
Fixed the issue by finding the VPS on hostinger and adding the port to it!
i was having the same issue and you should use the IPV4 adress to connect it worked for me and my friend
